Partlist
Exported from BandidoIIuMax_rev301Final.sch at 26.09.2005 15:21:19
Part       Value          Device       Package    Library        Sheet
AUX-FREQ                  M03          03P        con-amp-quick  1
BATT-TEST                 M02          02P        con-amp-quick  1
BATTERY-IN                M02          02P        con-amp-quick  1
C1         470n           CAPNP-5      C-5        discrete       1
C2         47n            CAPNP-5      C-5        discrete       1
C4         100u           ELC-5        ES-5       discrete       1
C5         100u           ELC-5        ES-5       discrete       1
C6         220u           ELC-5        ES-5       discrete       1
C8         220u           ELC-5        ES-5       discrete       1
C9         100p           CAPNP-5      C-5        discrete       1
C10        130p           CAPNP-5      C-5        discrete       1
C12        180p           CAPNP-5      C-5        discrete       1
C13        22p            CAPNP-5      C-5        discrete       1
C14        18p            CAPNP-5      C-5        discrete       1
C15        33n            CAPNP-5      C-5        discrete       1
C16        120p           CAPNP-5      C-5        discrete       1
C17        220n           CAPNP-5      C-5        discrete       1
C18        30p            CAPNP-5      C-5        discrete       1
C42        100u           ELC-5        ES-5       discrete       1
D2                        DIODE-7,5    D-7,5      discrete       1
D3                        DIODE-7,5    D-7,5      discrete       1
D4                        DIODE-7,5    D-7,5      discrete       1
D5                        DIODE-7,5    D-7,5      discrete       1
D6         1N4735A        1N4728       DO41Z10    diode          1
D7                        DIODE-7,5    D-7,5      discrete       1
DISK100K                  M03          03P        con-amp-quick  1
GROUND50K                 M03          03P        con-amp-quick  1
IC1        4024           4024N        DIL14      40xx           1
IC2        2931A          78XXS        78XXS      v-reg          1
IC5        LM393          LM393N       DIL08      linear         1
IC7        MC33178        LF442N       DIL08      linear         1
JACK                      M03          03P        con-amp-quick  1
LED1       RED            LED5MM       LED5MM     led            1
LED2       GREEN          LED5MM       LED5MM     led            1
ON-OFF                    M02          02P        con-amp-quick  1
PAD1                      2,15/1,0     2,15/1,0   wirepad        1
PAD2                      2,15/1,0     2,15/1,0   wirepad        1
PAD96                     2,15/1,0     2,15/1,0   wirepad        1
PAD97                     2,15/1,0     2,15/1,0   wirepad        1
PAD98                     2,15/1,0     2,15/1,0   wirepad        1
PAD99                     2,15/1,0     2,15/1,0   wirepad        1
Q1         2N3906         2N3906       TO92-EBC   transistor-pnp 1
Q2         2N3904         2N3904       TO92-EBC   transistor-npn 1
Q3         2N3904         2N3904       TO92-EBC   transistor-npn 1
Q4         2N3906         2N3906       TO92-EBC   transistor-pnp 1
Q5         2N3906         2N3906       TO92-EBC   transistor-pnp 1
Q6         2N3904         2N3904       TO92-EBC   transistor-npn 1
Q7         2N3906         2N3906       TO92-EBC   transistor-pnp 1
Q8         BC556A         BC556A       TO92-EBC   transistor-pnp 1
R1         1.2k           RESEU-7,5    R-7,5      discrete       1
R2         12k            RESEU-7,5    R-7,5      discrete       1
R3         20k            RESEU-7,5    R-7,5      discrete       1
R4         47k            RESEU-7,5    R-7,5      discrete       1
R5         10k            RESEU-7,5    R-7,5      discrete       1
R6         10k            RESEU-7,5    R-7,5      discrete       1
R7         2.2k           RESEU-7,5    R-7,5      discrete       1
R14        20             RESEU-7,5    R-7,5      discrete       1
R15        5.1k           RESEU-7,5    R-7,5      discrete       1
R16        150            RESEU-7,5    R-7,5      discrete       1
R17        100            RESEU-7,5    R-7,5      discrete       1
R18        150            RESEU-7,5    R-7,5      discrete       1
R19        82k            RESEU-7,5    R-7,5      discrete       1
R20        1k             RESEU-7,5    R-7,5      discrete       1
R21        10k            RESEU-7,5    R-7,5      discrete       1
R22        20k            RESEU-7,5    R-7,5      discrete       1
R23        100k           RESEU-7,5    R-7,5      discrete       1
R25        20k            RESEU-7,5    R-7,5      discrete       1
R26        5.1k           RESEU-7,5    R-7,5      discrete       1
R27        5.1k           RESEU-7,5    R-7,5      discrete       1
R28        100k           RESEU-7,5    R-7,5      discrete       1
R29        100k           RESEU-7,5    R-7,5      discrete       1
R30        1k             RESEU-7,5    R-7,5      discrete       1
R34        47k            RESEU-7,5    R-7,5      discrete       1
R63        100k           RESEU-7,5    R-7,5      discrete       1
R64        10k            RESEU-7,5    R-7,5      discrete       1
R65        2.2k           RESEU-7,5    R-7,5      discrete       1
R67        1k             RESEU-7,5    R-7,5      discrete       1
R68        10k            RESEU-7,5    R-7,5      discrete       1
R69        27k            RESEU-7,5    R-7,5      discrete       1
R70        10k            RESEU-7,5    R-7,5      discrete       1
R97        470            RESEU-7,5    R-7,5      discrete       1
R98        330            RESEU-7,5    R-7,5      discrete       1
R99        220-470k       R-TRIMM      RTRIM      rcl            1
RX-COIL                   M02          02P        con-amp-quick  1
SL1                       M02          02P        con-amp-quick  1
SL2                       M03          03P        con-amp-quick  1
SL3                       M03          03P        con-amp-quick  1
SPEAKER                   M02          02P        con-amp-quick  1
TX-COIL                   M02          02P        con-amp-quick  1
